Use the following procedure to view the Intermediate-System-to-Intermediate-System (IS-IS) interface control packets.
- Select Stats.
- Select the Interface Control Packets tab.
Interface Control Packets Field Descriptions
Use the data in the following table to use the Interface Control Packets tab.
Name |
Description |
Index |
Shows a unique value identifying the Intermediate-System-to-Intermediate-System (IS-IS) interface. |
Direction |
Indicates whether the switch is sending or receiving the PDUs. |
Hello |
Indicates the number of IS-IS Hello frames seen in this direction at this level. |
LSP |
Indicates the number of IS-IS LSP frames seen in this direction at this level. |
CSNP |
Indicates the number of IS-IS Complete Sequence Number Packets (CSNP) frames seen in this direction at this level. |
PSNP |
Indicates the number of IS-IS Partial Sequence Number Packets (PSNP) frames seen in this direction at this level. |
